SOLVED - Volumetrics - VDB Explosion Not Showing Following Livestream
DiomedeDiomede Posts: 15,410
edited January 2024 in Daz Studio Discussion
Greetings.  I am trying to get a VDB explosion smoke effect.  No luck thus far.  I am following the method of Jay's Livestream video in the Daz+ forum.  My VDB file is the same as his, downloaded the explosion sample from openvdb.  Following Jay, I loaded a cube in my scene and used the geometry editor to change the default shader name to Volume.  The explosion.vdb file is loaded in the volume file channel.  I have tried it with Clip to Geometry both on and off.  The smoke volume does not appear in the viewport or render.  I must be missing a step.  I am using Daz Studio version 4.22.  Jay's Livestream example used version 4.20.
Source for VDB File.
What it should look like fllowing Jay's tutorial
What mine looks like with same explosion.vdb file
Post edited by Diomede on
  • felisfelis Posts: 6,151
    What light do you have in the scene?
  • DiomedeDiomede Posts: 15,410
    The default HDR
  • crosswindcrosswind Posts: 9,747
    edited January 2024
    You haven't defined proper Color in Multipliers of Scattering and Absorption...
    2031 x 1389 - 2M
    Post edited by crosswind on
    edited January 2024
    That was it.  Knew I must have missed a step.  Appreciate the help very much.  yes
    Thank you, @felis and @crosswind, for taking a look and helping me solve the problem.
    Cheers.
    VDB Livestream 11 SOLUTION check scattering multiplier and absorption multiplier gray and lighter ish respectively.png
    1876 x 1005 - 1M
  • Lan2050Lan2050 Posts: 14
    DAZ  smoke VDB  Not Showing  ,  This is it,  I have been seaching solution for a whole day.  Instaled uninstall DAZ 4.20 4.21 4.22 4.23 .
    Some how,  all my defualt colors are black, ( the Multipliers of Scattering and Absorption)   ,  exactly like Diomede's
    and no that default color shouldnt be a black one , thats a totally disaster ,  this tiny problems kills my 1 day ,  almost no solutions can be found everywhere.
    Thanks crosswind great help.    Thanks to Diomede. if I  dont find this post,  I can't sleep. have a nice day!
    2011 x 1344 - 617K
