symmetry stopped working correctly in vertex modeler -picks wrong points
DiomedeDiomede Posts: 15,393
I am in Carrara's vertex modeler. Had been modeling with symmetry, no problem for an extended period. Then, for reasons unknown to me, the vertex modeler started picking the wrong point.
I demonstrate in the attached pic. I have symmetry on. The model is symmetrical. I have selected a point on the left side with coordinates x=0.03, y=0.26, z=5.65. The vertex modeler does select a point on the other side, but instead of selecting the correct point at x=-0.03, y=0.26, z=5.65, which exists and is the mirror point, Carrara has selected a point at x=-0.04, y=0.27, z=5.65.
Hmmmm. Any ideas?
I have tried turning symmetry on and off, saving and reloading the model, and switching between the modeling room and the modeling in the assemble room feature. No luck so far.
  • de3ande3an Posts: 915
    Have you tried selecting the entire head and then choosing "Center Symmetry Plane On Selection"?
    If the head-object is truly symmetrical and has not been rotated, then this should work.
    1024 x 819 - 186K
  • DiomedeDiomede Posts: 15,393
    Thanks for the suggestion. I will try it out when I get home. That might solve it if I inadvertently centered the workingbox on a different point.
