Export movie with timecode?
in The Commons
Is there a way to export a movie file with a timecode? When I open an exported shot in Quicktime, for example, I just see a seconds counter, not a frame count.
Image sequence?
You could do it in premiere and I'm assuming Davinci resolve, but you're not going to get the timecode through Daz. But you can render your animation and run it through one of the editing programs and put it on no problem.
Thanks. I'll look into adding it in Premiere or something. I don't believe there is a way to add an audio track to Daz so I need to track frames to I can animate a gesture to land with a piece of dialogue. So I need to track what frame the word is spoken on.
Yep, that'll work! I shoot reference for all my animation, plug it into my after effects or premiere timeline with the audio where it needs to be and match the frames between there and daz or blender. Just make sure the frame rate is the same and you'll be good to go!
