A bunch of OOT (outoftouch) hair crashes Daz Studio in latest version
The application crashes when I try to load https://www.daz3d.com/dallas-pigtails-hair-for-genesis-3-and-8-females, https://www.daz3d.com/madeline-tails-hair-for-genesis-3-and-8-female-s, or https://www.daz3d.com/marigold-hair-for-genesis-3-and-genesis-8-female-s
Some other OOT hair does seem to be working, such as https://www.daz3d.com/2021-01-hair-for-genesis-8-females
I recently upgraded to Daz Studio 4.22.15. Previously I was on 4.21.05 and things where working fine then.
I'm posting this here because I can't report a bug anywhere. All links I can find are dead or point to pages that don't do what they should. The built-in report function also seems to be disabled.
Post edited by frits.vancampen on
  • SofaCitizenSofaCitizen Posts: 2,112
    edited January 2024
    The link at the footer of the page works: https://bugs.daz3d.com/hc/en-us
    Have you updated all those three hairs to the version released on 2023-01-24?
    EDIT: Just to double-check (since I usually just use the Beta now) I just loaded and part-rendered all three hairs on 4.22.0.15.
    800 x 640 - 843K
    Post edited by SofaCitizen on
  • This has been discussed in the beta and release threads
    https://www.daz3d.com/forums/discussion/656716/daz-studio-4-22-0-x-pro-general-release#latest
    https://www.daz3d.com/forums/discussion/665996/daz-studio-pro-beta-version-4-22-1-54-updated#latest
    Mostaffected products have been updated, but since the issue is a shared file the installation order and method matter (as does having an older version of the file in another content directory). You can fix it yourself - select the hair in the Scene, select the hair in the editor tab of the Surfaces pane, type transm in the filter box at the top of the pane, and remove any map from the Transmitted Colour property by clicking the button to the left of the colour picker.
  • Ok, I got it to work. Richard's workaround works but remember to set your Viewport to Texture Shaded. In IRAY mode it will crash right away.
    In general, what's Daz's process for dealing with breaking changes? Can we expect this bug to get fixed soon or at all?
    I'm not a fan of requiring an asset creator to 'fix' their assets for minor version release. Typically, breaking changes are saved for major versions. It makes things more predictable, but that's not a word I would use for anything related to Daz indecision
  • Richard HaseltineRichard Haseltine Posts: 108,729
    edited January 2024
    nVidia would have to modify Iray not to crash, but having a map assigned to Transmitted Colour was incorrect so removing the maps is the basic solution.
    In order to keep plug-in/SDK compatibility Daz has integrated major feature updates in new minor versions, though we do know that an SDK-breaking DS 5 is coming.
