Daz 4.8 pc won't open
I click on the daz icon and it loads seemingly as normal but then the scene builder window shows up - the rest of the interface won't open. I can close the scene builder window and interact with that window but the main interface won't open, even though it says there's a window open. Help me, please? I'm on windows 7.
How did you install DS4.8, was it using DIM (DAZ Install Manager)?
If so, the simplest thing may be to uninstall/reinstall again. It only takes a few moment ins DIM to do that. I use Win 7, and the only time I had a problem, was when DAZ Studio was open (un-noticed) when I updated.
I've now uninstalled and reinstalled with DIM, the problem persists. :(
Other programs running? Especially security software?
There is microsoft security essentials running, but that's never stopped it before. I was happily using DAZ, then I tried to load a previous project and since then it's been broken.
Look in the log file...
Users/you/ApplicationData/Daz 3D/Studio 4
Users/you/AppData/something similar/to above...
Post any part that shows a clear error message.
I have no idea what I'm looking for in the log file I've found. I found a lot of things saying NOT INITIALIZED
Ok...the last few lines before the Not Initialized and first 3 or 4 of those lines.
GL_AMDX_name_gen_delete : NOT INITIALIZED
GL_AMDX_random_access_target : NOT INITIALIZED
GL_AMDX_vertex_shader_tessellator : NOT INITIALIZED
GL_AMD_texture_cube_map_array : NOT INITIALIZED
GL_ARB_texture_snorm : NOT INITIALIZED
GL_EXT_copy_buffer : NOT INITIALIZED
GL_EXT_shader_atomic_counters : NOT INITIALIZED
GL_EXT_texgen_reflection : NOT INITIALIZED
GL_EXT_texture_buffer_object_rgb32 : NOT INITIALIZED
GL_EXT_texture_compression_bptc : NOT INITIALIZED
GL_EXT_texture_lod : NOT INITIALIZED
GL_SUN_multi_draw_arrays : NOT INITIALIZED
WGL_EXT_swap_control : NOT INITIALIZED
WGL_ARB_create_context_profile
: NOT INITIALIZED
WARNING: dzneuraymgr.cpp(261): Iray WARNING - module:category(LINK:PLUGIN): 0.0 LINK plug warn : loading C:\Program Files\DAZ 3D\DAZStudio4\libs\iray\nvcuvid_video_decoder.dll: The specified module could not be found.
Iray INFO - module:category(FREIMG:IMAGE): 1.1 FREIMG img info : fi_xpm (build 231000.11582, 29 Apr 2015) initialized
WARNING: dzneuraymgr.cpp(261): Iray WARNING - module:category(IRAY:RENDER): 1.1 IRAY rend warn : Failed to determine NVIDIA CUDA driver version; iray can only run in CPU mode. Please update your NVIDIA driver (www.nvidia.com).
Iray INFO - module:category(IRAY:RENDER): 1.1 IRAY rend info : Using iray plugin version 4.0, build 231000.11582 n, 29 Apr 2015, nt-x86-64-vc11.
WARNING: dzneuraymgr.cpp(261): Iray WARNING - module:category(IRAY:RENDER): 1.1 IRAY rend warn : There is no GPU available to the iray renderer.
Iray INFO - module:category(BLEND:RENDER): 1.1 BLEND rend info : blend render (build 231000.11582, 29 Apr 2015) initialized
Iray INFO - module:category(IRAY_CLOUD_CLIENT:NETWORK): 1.1 IRAY_C net info : iray_cloud (build 231000.11582, 29 Apr 2015) initialized
WARNING: dzneuraymgr.cpp(261): Iray WARNING - module:category(IRT:RENDER): 1.1 IRT rend warn : Your NVIDIA driver API 'nvcuda' cannot be found. All GPUs will be disabled.
WARNING: 3DConnexion Plug-in Error: Could not create Device, CoCreateInstance failed
3D mouse support library could not be loaded.
WARNING: QFile::flush: No file engine. Is IODevice open?
The rest is a lot like that.
No OpenGL and Iray is not finding anything usable, either...
What video card?
No idea :D But 4.8 used to work!
