Skyler skin 3delight
TheKDTheKD Posts: 2,711
edited July 2015 in The Commons
Skin is not looking right to me, I don't use iray at the moment. It seems like the bump setting is off, and there is some grid as well. Oh, probably should mention it's g3f version of her.
Post edited by TheKD on
  • lcfarlcfar Posts: 88
    Yeah, I saw the same thing. Also using 3Delight and G3F version. Didn't matter what light I used, either (viewport, distant, AoA Advanced) or what shading rate. The only thing that fixed it was turning down the Bump Noise Strength on the skin surfaces to 10% or less. For some reason, it came set at 48.4%.
  • TheKDTheKD Posts: 2,711
    Ah thanks, dropping that down did the trick. I normally don't render in daz studio, only when I need to redo bad icons, or make .tip files and whatnot. No reason to set up a houdini scene for something that simple.
