Cyprus Tree Exported to Unreal leaves are glitchy?
RexRedRexRed Posts: 1,493
edited December 2023 in Unreal Discussion
I tried to raise/lower the opacity mask clip value of the texture in Unreal and that did not stabilize the color.
Any suggestions on this would be much appreciated.
Post edited by RexRed on
  • metasidemetaside Posts: 178
    Without additional info and pictures it's hard to even guess what's happening.
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,004
    edited January 2024
    there are 2 ways of achieving opacity in Unreal,
    Transparency is not the same as masking and tends to give the effect you are describing
    your mask should be only 2 channels black and white for the best results
    also dithering
