Gen 9 Figure morphs
I am having a problem when loading any gen 9 figure, even the dev load, as it always loads with unwanted morphs that are set to a value other than zero, the figure is thus distorted, so I have to zero out everything on the morph dials before I can progress.
I have tried loading the dev load figure, zeroed all dials and then saved as support asset thinking it might reset the figure, but when the dev load is tried again all the same morphs and values are back again.
Any thoughts what I can do?
Moved to Technical Help as it is not a Daz Studio application topic.
What support asset? You would want Save Modified Assets - but make sure you don't end up zeroing the enabler for the correctinve morphs in the process. You could also, and more safely, use the list of properties to be saved in the Save Modified Assets dialogue as a pointer towards the rogue, then cancel the save and turn your attention to fixing just the rogue (if it doesn't have an update already).
