Genesis 9, Inflating Cloth in Marvelous designer 11 (Solved)
James
I use MD 11 to make a morph of other people clothing.
But recently I use genesis 9. And everytime I simulate a cloth in MD 11 on Genesis 9 avatar, the cloth inflating very much.
Do you know how to not make the cloth inflating on G9?
Post edited by James on
What do you mean by "make a morph of other people clothing" ? You import clothing from DS into MD and simulate it based on a G9's avatar ?
How does the "inflating" look like ? sort of collapsing ? (with unwelded mesh...?) Better post a screenshot.
Something like this:
https://prnt.sc/ke05VI9tPt_Z
This suposses to be a tight fit leggings.
Ho ~ interesting... So after you imported the leggings into MD, they were slim and fitted. But after simulation, they inflated like that ?
Have you checked the settings of Skin Offset and Particle Distance there ?
And the leggings are from a product or a freebie or you made them?
from a product.
Skin offset and particle distance has no effect.
And I shouldn't change the particle distance, cos the geometries will change, and I can't import it back as a morph.
If you import it with no patterns from that product, there won't be settings of particle distance ~~
I just don't know why... unless you name the product that I can check if I have it for a test...
Edit: Actually, if you wanna make an FBM on this item for a G9 character, you don't have to sim it in MD with G9 avatar or morph target. Instead, you may do it in DS, by using dForce modifier, with a lower Contraction-Expansion Ratio, then export / import via Morph Loader Pro, that'll also do.
I need to do it on MD for certain reason.
Ok... so have more tries with it.
I've tested with GF8.
The same thing occurs.
So, it's not a G9 problem.
I don't know what's going on.
I use fresh install of md, still no effect.
https://prnt.sc/7jj9lS1CMqHW
EUREKAA!
It turns out, I imported the avatar and garment in mm.
So the figure became a 'miniature' which causing the normal skin offset measurement becomes very large relative to the mini figure.
Hahaha~~ I did not thought of that though I asked about skin offset, as I know you are not a newbie to MD
Good!
