Catalyzer eyes fuzzy
vonHobovonHobo Posts: 1,711
edited December 2023 in The Commons
I am using the product Feline Essence Poses for Genesis 9 and Tiger | Daz 3D
To get fur on big cat 2 with catalyzer  I am using Real Fur for DAZ Big Cat 2 | Daz 3D
Haven't used the catalyzer product for a while now, but just tried it and eyes are all fuzzy in render (see attached).
It used to work just fine. Wonder why it doesn't render the eyes now, except for very pixelated.
If I just use the big cat 2 without the fur, it's fine.
Post edited by vonHobo on
  • felisfelis Posts: 5,818
    I would say it looks like it needs to render longer.
  • vonHobovonHobo Posts: 1,711
    It renders very quickley, like in 1 minute.
    I haven't adjusted my render settings and all other renders take longer and are very clear. Just this product causes this.
    Big Cat 2 product by itself (no extra fur) renders just fine. Eyes look great.
    Just the catalyzer fur product is doing this. maybe increase render time in Catalyzer pane??
    What is your stop criteria?
    The fur and the character is also very noisy.
    I don't see a stop criteria setting. I'll have to do some research to find where it is.
    If you to to Render Settings > Progressive Rendering, you have the different stop criterias, no of samples, time and quality.
    If one is reached the render will stop.
  • crosswindcrosswind Posts: 9,592
    Render Settings - turn off "Rendering Quality Enable" if it's on. Set Max Samples to 2500 - 3000, then Render to see if it's improved or not.
    The attached SS is rendered with 2500 Max Samples, the eyes seem fine.
    2560 x 1400 - 2M
    Post edited by crosswind on
    That worked. Thank you!
