File not found.
Cat_Dancing
Hello. Has anyone experienced this problem please. Is the a solution. (See attached pic)
Thank you.
Cat_Dancing
Thank you.
What is your DS' version ?
BTW, try to install this product via DIM first.
Hi Crosswwind. Thank you for your comment. I've run out of time right now but will continue tomorrow when I can try your solution.
My DS version is the latest update.
Best wishes. to you.
It has been installed through DIM or manually - the user is, however, working on-line.
This tends, as I recall, to be a metadata issue.
