File not found.
Hello. Has anyone experienced this problem please. Is the a solution.  (See attached pic)
Thank you.
  • crosswindcrosswind Posts: 9,648
    What is your DS' version ?
    BTW, try to install this product via DIM first.
  • Hi Crosswwind. Thank you for your comment. I've run out of time right now but will continue tomorrow when I can try your solution.
    My DS version is the latest update.
    Best wishes. to you.
    It has been installed through DIM or manually - the user is, however, working on-line.
    This tends, as I recall, to be a metadata issue.
