A SPECIAL SHIN MORPH
Cyklone
Hi everybody !
A question :
Is there any morph I should be looking for to get some kind of backward curve on shins ( as on the sample in attached file, before and after ), wich I find much more dynamic and realistic that straight shins ( just me though^^) ?
As I'm french, it's not easy to find the right property, the right morph or its name...What is the name for that, what should I be looking for ?
...Or is there a pack of morphs including this that I could by for G8F / G9 ?
At the moment the only solution that I've found is to go through a body morph called "space elf" but it changes the whole body so it needs retweaking afterward...can be very annoying !
Any help would be greatly appreciated !
In advance, a big thank you !
Cheers !
That muscular part of the lower leg is called the Calf (plural Calves).
For G8F there is a morph in the Genesis 8 Female Body Morphs (which you may already have) called "Calves Size" which might do what you want but I'm not sure - there's a promo picture that shows larger calves on the product page.
For Gen9 there is a similar morph in Genesis 9 Body Shapes (again you may already have this).
This gives many kinds of morphs for lower legs that are not available otherwise.
THe problem is not really to have bigger bigger calves, in fact it's a deformation knee + shin that give an effect as if the shin was curved a bit backward.
If you compare the first and the second photos, you can see that the knee angle is not the same and the front of the shin seems a bit curved.
Overall, for my personnal taste, legs are looking more dynamic, less straight, more natural...
I've tried "Killer legs" and there's nothing about that inside.
