Will Stephanie 5 skins work on victoria 5? Daz
Serene NightSerene Night Posts: 17,704
Will the STephanie 5 skins work on Victoria 5? I don't yet have Stephanie, but I like one of the skins, and am curious....
  • scorpioscorpio Posts: 8,533
    The skins will work with the V5 morph or any other genesis morph, but if Steph5 has her own UV map you will need the base to use them, if they use it not all textures made for certain morphs use that UV.
  • LindseyLindsey Posts: 2,009
    edited August 2012
    Stephanie 5 does come with her own UV Set.
    Riley for Stephanie 5 uses the V4 UV Set.
    Keira for Stephanie 5 uses the S5 UV Set.
    I switched the UV Set on these textures to determine that you need to stick to the Stephanie 5 textures that uses the V4 UV Set. If the product pages don't state the UV Set, I'd suggest you just ask in the forums. I'm sure someone will chime in what UV Set the texture uses.
    Post edited by Lindsey on
