Custom category on product tab ?
MelonLord
Does anyone know how to create a custom category on product tab (like the one in pic) ? Would be great if i could create a category inside default but i'm not sure if it's possible. My plan is to put several 3rd party poses and expression under one separate category
Post edited by MelonLord on
Go to the Content Library pane, then you just right-click on the space and choose "Create Sub-Category". You can create sub-categories under Default, but I prefer to keep my custom categories outside of default.
I didnt knew they were under there! cool, so how do i place products there ?
Go to the product you want, you can either right-click on the product folder and choose "Duplicate Category" and choose the new location, or select one or all of the items inside the folder, right-click > Categorize, then you can put them in a category you've already made or make a new category to put them in.
It worked! Thanks a ton
Personally suggest you create user-defined categories under Default... otherwise it'll bring you multiple (at least two...) Root Categories in Smart Content and delay product Refresh, especially when you have many products installed... and you have to click to expand each time after Refresh..
User-defined categories will be marked with U on the icons, so it's easy to differeantiate "User-defined" and "Is Vendor"
