Trouble transferring Materials with RSSY Clothing converter G8 to G9
The scrupt transfers the outfit but not Materials or Dforce settings for that matter. So I go back to select material files so i can transfer or convert them to the new directory for G9 and it gives error message "No Clothing Files Added" and instructs me to check some option boxes whitch I do, but it does not convert material files for the dress, it just transfers it without any features as intended.
According to the product information on its page, it edits the metadata so that you can use the materials from Smart Content for both the G8 and G9 versions of your clothing. It doesn't copy the materials files themselves, and unfortunately, the product information page doesn't say that. The manual is also a bit unclear; it says that it removes materials files from certain types of conversion without explicitly saying that it will not copy materials files.
Anyway, to be clear, the script doesn't transfer materials files at all. It only alters the metadata in Smart Content so they can be used with the new version of the clothing. If you don't use Smart Content, you'll need to copy the materials files to your new directory yourself.
More information is available in the vendor's support thread: https://www.daz3d.com/forums/discussion/614111/released-rssy-clothing-converter-from-genesis-8-to-genesis-9-commercial/p1
That's right as vwrangler says. RSSY Clothing Converters (no matter which version) never transfer matetrial presets because the UV(s) of converted clothing has no change. You can just apply the original material preset from G8's product to the converted ones.
