Uggg, updated Daz and lost plugins...again.
It seems as though everytime I update Daz studio, there is a handfull of plugins that just dissapear. They are always the same so I am prepared, specifically Mesh Grabber and its add on's, and D-force Assistant. I usually just grab them from my account library and re-install the plugins myself. The core program, Mesh Grabber uses a .exe file though and for some reason it will not take this time. I run the .exe installer and everything goes fine, I hit finnish, then go into Daz Studio and it is nowhere to be found. The two add on programs, meshgrabber rotations and morph editor are there but that is expected because I installed the .dll file manualy. I can't do that with the core program because it is an installer. I'm not sure how to proceed. Anyone else have this issue? I have restarted my PC after using the installer thinking it might have needed a restart, but no luck.
I use DIM and never lost a plugin to date.
Mesh Grabber is available as a .zip
How are you updating? Are you creating a new install path?
