Deepsea Eve for Genesis 9?
Will there be a Deepsea Eve for Genesis 9 to go with DS Adam for G9?
I own both the G8 figures with the same names and they are absolutely incredible.
How do I contact the PA to ask about Eve for G9?
DS Adam for Genesis 9 | Daz 3D
Post edited by vonHobo on
You could just transfer the Eve shape to G9. This method is really easy.
I can't speak for the OP, but I'd guess that the UV and/or textures are what they're after.
Thank you. I will look into the transfer thing. But I would love to have the actual figure if/when it comes out. I know these things take time.
Looking at both products, the G9 version looks to just be a normal character with the standard UV map, unlike the G8 Adam version. If so, then just transferring the G9 female version over to G9 would do the trick
OK. sounds good. I will try it.
And then hope a G9 Eve is released by the PA.
You could edit your first post and move the thread over to Product Suggestions where the PA may or may not see it.
