I'm having a bad hair day
EmotionalOutlet3DEmotionalOutlet3D Posts: 243
I'm having a problem with Flirty Hair and I'm not sure if it is an actual problem with the hair itself /and or if there is a way to fix it? I thought it might be because I'm trying to render it with Iray but it also happens when I use 3Delight it is just less noticeable. It shows up even without adjust the parameters. It is most irritating as I like the look of the hair. I've attached the render with the areas circled in red. I suppose I can postwork it to fix it but If anyone has an idea how to fix it it would be much appreciated.
    Select the hair, go to Parameters, click the Options (lined paper looking box with an arrow on it) and check Show Hidden. Then currently used...look for the head/face/eye morphs...and dial them out/back until the crinkles go away.
  • EmotionalOutlet3DEmotionalOutlet3D Posts: 243
    Thank you kindly! It was a couple of character morphs causing the problem and once zero'd out it fixed it. If I don't learn at least 2-3 new things a day then I'm not happy so you have contributed greatly to my well-being. :)
    And since I have your attention thank you, thank you for the eye morphs at ShareCG which I also used in the image. They work the ticket.
