How to get Genesis 8 expressions working on Genesis 8.1
12346»
  • LoonyLoony Posts: 1,817
    Richard Haseltine said:
    Yes, Genesis 8 expressions work on Genessi 8 figures - it's only 8.1 that uses a different system, and blocks the Daz Genesis 8 Expressions.
    Okay thanks, then will I try to figure out how exactly I have to use the tutorial from the start page :D with all the edits and updates it's a bit confusing for my simple mind :)
    The instructions on the first post are still wrong.
    Making the G8 base expressions (and any expressions that are using them) work on G8.1 requires removing dummy/placeholder expressions that are installed to G8.1 morph folders - These dummy/placeholder expression files have no other function than to prevent the base G8 expressions from loading.
    The dummy/placeholder files are located in;
    ...\Data\DAZ 3D\Genesis 8\Female 8_1\Morphs\Daz 3D\Base Pose Head\ (255 files, can be more if you have additional DAZ expression packs)
    ...\Data\DAZ 3D\Genesis 8\Female 8_1\Morphs\Daz 3D\Expressions\ (24 files, can be more if you have additional DAZ expression packs)
    ...\Data\DAZ 3D\Genesis 8\Male 8_1\Morphs\Daz 3D\Base Pose Head\ (255 files, can be more if you have additional DAZ expression packs)
    ...\Data\DAZ 3D\Genesis 8\Male 8_1\Morphs\Daz 3D\Expressions\ (24 files, can be more if you have additional DAZ expression packs)
    Please make sure you are removing the files from G8.1 morph folders and not G8 morph folders.
    Note 1; If you are logging in to DS and letting DAZ Connect (within DS) to install/update your content, you may have these also in an other location that has "\Data\Cloud\" in it's path
    Note 2; Do not remove any files from "FACS" or "FACSExpressions" folders
    "These dummy/placeholder expression files have no other function than to prevent the base G8 expressions from loading. "
    Why got they then even installed O_o?
    I will just delete them, I assume I shouldn't delete the folder "base pose head" or "Expressions", I will safely just delete the files inside now.
  • Matt_CastleMatt_Castle Posts: 3,097
    As far as I understand it (and, as far as I know, I was the first to find and post a fix), it's because Daz wanted to update G8.1's face controls without requiring vendors to have to support both sets of face controls.
    Although it'd be nicer if Daz had found a way to set this up so that the installer could say "hey, you can still have these controls, but they're not officially supported on G8.1 characters, so you might get odd results", it would indeed be a bit much for vendors to have to do two sets of face testing and correctives.
  • crosswindcrosswind Posts: 9,739
    As far as I understand, when Daz developed FACS ( those 52 "blend shapes" ) on G8.1 to support Face Cap via ARKit,FACS should've been with a well-designed naming convention for property Labels, just like Laylos' Face Mojo... Then leave it to the users to choose which and how to use them rather than defining dummy files to block G8.0' base facial and expression dials...
    So I changed the Lables to differentiate them... and practically, if you can wisely dial these properties, you can well "mix" them.
    549 x 785 - 114K
    edited December 2023
    Thanks for your feedback about your thoughts.
    Thanks now it works :)
    Post edited by Loony on
  • Silly that you have to go to these lengths really. I mostly work with gen 9 but sometimes I just need extra characters and the 8.1 ones I use are annoying as hell because of stuff like this. Will Daz ever fix this backward compatibility?
  • LeanaLeana Posts: 12,981
    Most likely not, because disabling G8 expressions was done on purpose since there is a new system in G8.1. Hence why people who want to use the G8 ones have to use this procedure.
    So Daz can sell you a new set of expressions for Gen 8.1 when you already have a perfectly good set for Gen 8.
  • Updated to the latest 4.23 and had a meal of a time getting the G8 expressions to work on 8.1. However I think I managed it by just removing the base pose head and expression folders so it seems to be working
  • Apparently, this also hides in DAZ 3D\Studio\My Daz Connect Library\data\cloud\1_42077\data\daz 3d\genesis 8\female 8_1\morphs\daz 3d and DAZ 3D\Studio\My Daz Connect Library\data\cloud\1_42071\data\daz 3d\genesis 8\female 8_1\morphs\daz 3d and other, similar locations.
    That is from installing the product with Daz Connect (that is, through Daz Studio itself).
  • this is gonna sound really silly but i'm very new to daz so bear with me!
    is there a way to reload the model without removing them and having to start over?
    i've fully made a character with lots of tweaks and things but then i found out that the expressions didn't work
    so i've followed the guides here, deleted the 8.1 dummy expressions but expressions still don't work,
    i hear you need to "reload" the character for the changes to work but i really don't want to start over!
    thanks!
    thanks!
    Reload your character from disc, or if you haven't saved it then save it now and reload that - it is a matter of making DS rescan the available properties, something it won't do while the figure is just sitting in memory; it doesn't mean you have to start from scratch with the base figure.
  • greywolfgreywolf Posts: 137
    [I had started my own thread on this asking kind of the opposite question as the 8.1 expressions on an 8.1 character weren't working right -- smile full face, smile open full face, and I think frown wasn't working either.  No idea what I needed to do to fix this; I ended up removing all assets, uninstalling daz, reinstalling daz, reinstalling all assets (with ~2700 assets this was prohibitively a time-expensive operation). ]
