rendering - Problem solved.
efron_24
i installed 4.22.01 today
Should not have done that
suddenly DAZ does not render anymore
It opens the render window.. and stops instantly with a black field.
Nothing rendered...
Wish i could return to an older version
wondering how
Post edited by efron_24 on
Did you upgrade to the latest driver for the GPU, assuming you have an NVIDIA? The new version of DS requires it.
and the next version will require an even later minimum driver version http://docs.daz3d.com/doku.php/public/software/dazstudio/4/change_log#4_22_1_29 - this is very likely to happen with Iray updates.
problems sloved
wow... I found it out and it works again
thanks to you 2
