Pose Architect Add-on Pack 1 for Genesis 8 Female (Problem) [Solved]
RedStoneRedStone Posts: 3
Hello, I need help with a product. I bought Pose Architect Add-on Pack 1 for Genesis 8 Female.
But when I load a new genesis 8 female with zero pose, hip Y Translation is '-0.0000014'.
I can't get consistency with previously saved data.
Could anyone help me ?
Post edited by RedStone on
  • crosswindcrosswind Posts: 10,253
    You're very careful. yes
    The culprit - there're two dials: pCTRL3duPAP1TorsoWeight01L and pCTRL3duPAP1TorsoWeight01R, with wrong ERC [Keyed] range value. (screenshot1: solution 1)
    Quicker way: go to data folder from File Path in Parameter Settings, directly modify two dsf files. Uncompress them by using Batch Convert - Windows - Panes - Batch Convert, and correct the values as per the screenshot2
    Then submit a ticket to Daz as you wish.
    2017 x 1397 - 268K
    1172 x 1320 - 128K
  • Thanks!
    I modified five dsf files: pCTRL3duPAP1TorsoWeight01L, pCTRL3duPAP1TorsoWeight01R, pCTRL3doPAP1CrossLegsStandingL.dsf,  pCTRL3doPAP1CrossLegsStandingR.dsf, pCTRL3duPAP1SquatFloor.dsf.
    And now I load a new genesis 8 female, hip Y Translation is '0'.
    RedStone said:
    Thanks!
    Ha ~ good! I missed the other three 'cause of cache issue. Thank you!
