Morph limits
AngelAngel Posts: 1,204
Do you ever get those morphs that when you go into the parameters settings and you uncheck use limits and It still limits the morph?
Is there a way to get around that? There is one morph I need to reverse and it wont go backwards beyond -100% Even with Use Limits off
  • Richard HaseltineRichard Haseltine Posts: 111,475
    While you are in the Parameter Settings dialogue click the Sub components tab at the bottom - I think you will find that the morph(s) listed there are the ones that change the mesh, so you need to find them (you may well need to enable Show Hidden Parameters in the pane's option menu - the lined button in the top corner, or right-click the tab) and turn off their limits too. You do need to be wary about turning limits off entirely - sometimes a morph will do bad things if it goes to zero; a more cautious approach is to increase the maximum value to allow for the effect you want while leaving limits on.
