3delight uses max sudivison regardless of te settings
[3delight uses max sudivison regardless of te settings] just like title say i set to 1 but its always on max in render
3Delight has sub- or micro-polygon displacement, unlike iray and many otehr renderers it doesn't need explicitly declared divisions. Whata re you trying to achieve by having a low division level?
faster rendering and my pc not freezing during 10 minutes i can use iray but i like 3delight
If you can avoid using HD morphs, that will save you some rendertime. You need to make sure the levels are 0 for them to not be active.
