I broke Iray, again.
844d1cc615844d1cc615 Posts: 92
edited December 2023 in The Commons
Once in a while some solids, primarily G9 figures will render with PNG transparency.  I can fix in Photoshop by creating a black layer under it.  I've played with max path length, reinstalling drivers etc.  Nothing seems to fix it.  Then one day it'll just stop.  Anyone else ever experience this?
Post edited by 844d1cc615 on
  • TotteTotte Posts: 14,809
    Weird - what is your settings for image min/max size for Iray? Looks a bit like heavy compressed image maps to me.
  • sidsid Posts: 540
    Assume you've checked the log and 'currently applied' parameters to make sure something strange isn't auto loading?
    Do you by chance have multiple GPUs? I have had this happen sometimes when one of my GPUs runs out of VRAM and stops rendering. Normally it works fine. And once this event happens, it did not go away. Disabling the GPU that ran out of VRAM did not help right away. I had to restart DS to make this go away, and only select the one GPU that was able to fit the scene.
    I also saw a similar thing happen that I cannot explain. I had plenty of VRAM but the render became more and more transparent over time. It did this even after restarting. This was Daz 4.21. I switched over to 4.16 and it rendered fine. This case is different from the other, because the scene in question somehow caused it. It was the environment.
    If VRAM is not your issue, do a test removing the room your character is in. If it renders ok, it is something up with the room, and possibly associated with a bug introduced by Iray in 4.21.
  • Matt_CastleMatt_Castle Posts: 3,051
    What is your Draw Dome setting?
  • 844d1cc615844d1cc615 Posts: 92
    I think I got an idea of what is happening.  It involves:
    1. Not using Win11 as Admin
    2. Mesh Grabber (required elevated privilages)
    3. Big Win11 updates.
    This creates the ghost directory [WARNING] :: D:\DAZDevel\Hudson\HUDSON_HOME\jobs\NB_Studio_Trunk\workspace\src\sdksource\fileinput\dzassetdaz.cpp(697): Formula output property not found:
        File: /data/Daz 3D/Genesis
    and that creates all kinds of problems for me.
    Solution #1:  1st, uninstall Mesh Grabber.  2nd, uninstall affected items listed in log.txt.  3rd, Reinstall items.  4th,  Reinstall Mesh Grabber.
    Solution #2:  1st, Uninstall DAZ Studio.  2nd, reboot.  3rd, run Disk Cleanup.  4th, reboot.  5th, reinstall DAZ Studio.
    Solution #3:  1st, make sure everything is backed up.  2nd, wipe drives.  3rd, reinstall Windows OS.
    Solution #4:  Take PC to private range, build new one.
    Oh, I'm running just one RTX card these days.  Clean reinstalling studio drivers will not fix this issue.  You have to make DAZ Studio understand there is no Hudson anything on D:\.  A .bat file to do this would be nice.  I could boot to thumb drive containing a forensics distro to get a better look into this but I'm going to run some more tests inside Windows hoping it won't come to that.
    Oh, Render Settings are not a factor.  Draw Dome On/Off, Scene Only, all Environment products and render settings are not the issue here.  That was my first thought though.
    Oh, Running DAZ Studio 4.22
  • No Daz Studio plug-in will require elevated privileges. The Hudson path is not a ghost directory, it is the path to the DS source code and is given as an aid (for the developers) in debugging, should the issue it is reporting require that.
    Thank you Richard.  When I say elevated privilages I mean it doesn't run either isolated within a non-Admin user account or within a contained folder, a standalone app if you will.  I'm using "elevated" as a sort of blanket term here.  When you install Mesh Grabber and you're not running Windows OS as Admin you are prompted to enter your Admin password.  Hence the term "elevated."  DAZ Studio also requires this.  It is common in operating systems when installing software (for users who may have picked this up via a search engine).  I do wish Microsoft would eliminate the usable Admin account making it only accessable via a terminal window or in this case cmd, powershell.  That would be one less variation to work around when troubleshooting.  When I have Meshgrabber installed instead of the reguIar DAZ splash screen there is a secondary window that opens & closes so fast you can't see what it is.  I am not saying it is the equivalent of gaining root access to the kernal.  I haven't even checked if it creates a Windows registry key.  I'm only able to type this now because of Summatriptan, anti-inflammatory, anti-convulsive molecules & Vernors soda.  To say I'm a little rusty is a spectacular understatement so "with a grain of salt" ya know?  I shouldn't have used the term "ghost directory."  My bad.  I am a very buggy OI machine these days.  I first discovered the Hudson path in my log.txt after installing Mesh Grabber & later updating to a new Win 11 build a while back.  I do not know if it played a role or if the Win 11 update would have caused the issues on it's own.  I do know I did not reinstall it for a while.  It's from a trusted source & it's not a priority for me right now.  How I may have resolved the issue in the next post.
  • I had already uninstalled Mesh Grabber.  This did not resolve the issue.  I never thought it was just a Mesh Grabber issue.  It just made sense to uninstall Mesh Grabber before uninstalling DAZ Studio.  When I plugged in one of my 2FA decryption keys Windows made the sound that the usb port was recognized however the usb drive containing the key did not load.  This was on metal, not a VM.  I hit the network kill switch & decided to do a portrait render I'd been planning.  I was able to complete it however the WARNING messages in my log.txt where taunting me.  I decided to uninstall DAZ Studio via DIM.  Reboot, uninstall DAZ Studio 4.22 in the DIM while connected to an outward network (the internet).  This triggered an automatic reinstall process.  During this process Microsoft Visual Studio C++ (I think.  I was getting very ill.) installs again.  Upon completion DAZ will open your default web browser to a page telling you to open DAZ Studio via a tab in the DIM.  While still connected to the internet I did this, waited for the default scene to settle then checked the DS troubleshooting file.  Gone were the concerning errors.  At first load log.txt indicated it was stopping the following or tracking of one G9 character I created using just sliders & ported G8 morphs.  Fine by me.  I created a scene containing only assets purchased from the DAZ store.  These are these are the results:
    2023-12-03 16:22:03.334 [WARNING] :: No DzLightsPane instance could be found in DzLGHTSBaseAction::getPane()
    2023-12-03 16:22:03.334 [WARNING] :: No DzLightsPane instance could be found in DzLGHTSShowHiddenAction::init()
    2023-12-03 16:22:03.334 [WARNING] :: No DzLightsPane instance could be found in DzLGHTSSyncWithSceneAction::init()
    2023-12-03 17:15:51.263 [WARNING] :: QColor::setRgb: RGB parameters out of range
    device 0 (NVIDIA GeForce RTX 9090ti just kidding): Allocated 1.969 GiB of work space (2048k active samples in 0.000s)
    12 minutes 1.36 seconds
    The only WARNING that remained is QColor::setRgb: RGB parameters out of range.  This wasn't one that was a priority to fix for me.  To be on the safe side I will delete all the scenes created since updating to the most recent Win 11 Pro build.  For now I'll just use 7-zip to create a simple encrypted compressed folder set to delete the originals upon compression completion and store .7z file away.  That way I have them but they won't be able to cause any problems.  In a couple months if everything is going well I may try opening one of those old scenes.  For now everything appears to be satisfactory.  Will update if I run into problems.  Attached is the basic test image I did, assuming it'll allow me to attach the file.
    1350 x 2400 - 442K
  • The warnings are harmless, I am not sure what causes them but as far as I know we all get those.
    Yup.  That migraine + flare-up yesterday knocked off a few IQ points.  I couldn't even remember the words WAN/LAN lol.  I did a second scene yesterday since reinstall.  This time offline.  That first one I did while online.  I recived more warnings offline & hudson returned to my log.txt.  I understand it's harmless but could it be DAZ Studio prefers to be connected?  A while back I did a 127.0.0.1 to a DAZ IP address I captures on my network in my hostfile just to see what would happen.  It didn't like it but still functioned.  I removed it within a day or two.  It was just a test.  Here's the warnings from the log.txt file offline, nothing critical:
    Connected to CMS: PostgreSQL 9.3.4, compiled by Visual C++ build 1600, 64-bit
    ___________________________________________________________
    2023-12-04 10:45:39.002 [WARNING] :: D:\DAZDevel\Hudson\HUDSON_HOME\jobs\NB_Studio_Trunk\workspace\src\sdksource\fileinput\dzassetdaz.cpp(10128): Alias property reference not found: Genesis8Female:/data/DAZ%203D/Genesis%208/Female/Morphs/3D%20Universe/G8F/ctrlMouthOH.dsf#ctrlMouthOH?value
    2023-12-04 10:45:39.002 [WARNING] :: D:\DAZDevel\Hudson\HUDSON_HOME\jobs\NB_Studio_Trunk\workspace\src\sdksource\fileinput\dzassetdaz.cpp(2517): Property alias not created!
    2023-12-04 10:45:39.007 [WARNING] :: D:\DAZDevel\Hudson\HUDSON_HOME\jobs\NB_Studio_Trunk\workspace\src\sdksource\fileinput\dzassetdaz.cpp(748): Formula target property not found:
        File: /data/Daz 3D/Genesis 8/Female/Morphs/DeviousDolls/Poses/DDGamerGirlPose03.dsf
        URI: Genesis8Female:/data/Daz%203D/Genesis%208/Female/Morphs/DeviousDolls/Poses/DDGamerGirlPose03.dsf#DDGamerGirlPose03?value
    2023-12-04 10:45:39.050 [WARNING] :: D:\DAZDevel\Hudson\HUDSON_HOME\jobs\NB_Studio_Trunk\workspace\src\sdksource\fileinput\dzassetdaz.cpp(697): Formula output property not found:
        File: /data/Daz 3D/Genesis 8/Female/Morphs/Raiya/Frida/CTRLFrida.dsf
        URI: Genesis8Female:/data/DAZ%203D/Genesis%208/Female/Morphs/Raiya/Frida/FHMFrida.dsf#FHMFrida?value
    2023-12-04 10:45:39.054 [WARNING] :: D:\DAZDevel\Hudson\HUDSON_HOME\jobs\NB_Studio_Trunk\workspace\src\sdksource\fileinput\dzassetdaz.cpp(697): Formula output property not found:
        File: /data/Daz 3D/Genesis 8/Female/Morphs/SickleYield2017/UniversalBreastHelper/PBMSYUBHGiantAll.dsf
        URI: Genesis8Female:/data/DAZ%203D/Genesis%208/Female/Morphs/SickleYield2017/UniversalBreastHelper/PBMSYUBHGiantAll_proj.dsf#PBMSYUBHGiantAll_proj?value
    2023-12-04 10:45:39.058 [WARNING] :: D:\DAZDevel\Hudson\HUDSON_HOME\jobs\NB_Studio_Trunk\workspace\src\sdksource\fileinput\dzassetdaz.cpp(748): Formula target property not found:
        File: /data/Daz 3D/Genesis 8/Female/Morphs/Zev0/Bend Control/Smoother M8 R.dsf
        URI: Genesis8Female:/data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Monique%208/FBMMonique8.dsf#FBMMonique8_Cage?value
        File: /data/Daz 3D/Genesis 8/Female/Morphs/Zev0/Bend Control/Smoother M8 L.dsf
        File: /data/Daz 3D/Genesis 8/Female/Morphs/Zev0/Bend Control/RShin CompressM8 Assist.dsf
    2023-12-04 10:45:39.059 [WARNING] :: D:\DAZDevel\Hudson\HUDSON_HOME\jobs\NB_Studio_Trunk\workspace\src\sdksource\fileinput\dzassetdaz.cpp(748): Formula target property not found:
        File: /data/Daz 3D/Genesis 8/Female/Morphs/Zev0/Bend Control/R Top FlattenM8 Assist.dsf
        File: /data/Daz 3D/Genesis 8/Female/Morphs/Zev0/Bend Control/LShin CompressM8 Assist.dsf
        File: /data/Daz 3D/Genesis 8/Female/Morphs/Zev0/Bend Control/L Top FlattenM8 Assist.dsf
    2023-12-04 10:45:39.060 [WARNING] :: D:\DAZDevel\Hudson\HUDSON_HOME\jobs\NB_Studio_Trunk\workspace\src\sdksource\fileinput\dzassetdaz.cpp(748): Formula target property not found:
        File: /data/Daz 3D/Genesis 8/Female/Morphs/Zev0/Bend Control/Center Smoother M8.dsf
    2023-12-04 10:45:39.082 [INFO] :: Sorting formula properties...
    2023-12-04 10:45:39.088 [INFO] :: Creating ERC Links...
    2023-12-04 10:45:40.082 [WARNING] :: D:\DAZDevel\Hudson\HUDSON_HOME\jobs\NB_Studio_Trunk\workspace\src\sdksource\fileinput\dzassetdaz.cpp(7934): Circular ERC!: DDGamerGirlPose01 with ERC ERC [DeltaAdd] > Genesis 8 Female : DDGamerGirlPose01
    2023-12-04 10:45:40.082 [WARNING] :: D:\DAZDevel\Hudson\HUDSON_HOME\jobs\NB_Studio_Trunk\workspace\src\sdksource\fileinput\dzassetdaz.cpp(7947): Unsupported formula: /data/Daz%203D/Genesis%208/Female/Morphs/DeviousDolls/Poses/DDGamerGirlPose01.dsf
    2023-12-04 10:45:38.778 [WARNING] :: D:\DAZDevel\Hudson\HUDSON_HOME\jobs\NB_Studio_Trunk\workspace\src\sdksource\fileinput\dzassetdaz.cpp(6770): Parent for modifier not found: FBM3duG8FStylized2021_body.
    2023-12-04 10:45:38.778 [WARNING] :: D:\DAZDevel\Hudson\HUDSON_HOME\jobs\NB_Studio_Trunk\workspace\src\sdksource\fileinput\dzassetdaz.cpp(2485): Modifier not prepared: FBM3duG8FStylized2021_body!
    2023-12-04 10:45:38.780 [INFO] :: Creating modifiers...
    2023-12-04 10:45:38.960 [WARNING] :: D:\DAZDevel\Hudson\HUDSON_HOME\jobs\NB_Studio_Trunk\workspace\src\sdksource\fileinput\dzassetdaz.cpp(2502): Modifier not created: FBM3duG8FStylized2021_body!
    2023-12-04 10:45:38.993 [INFO] :: Creating property aliases...
    2023-12-04 12:36:23.397 [WARNING] :: D:\DAZDevel\Hudson\HUDSON_HOME\jobs\NB_Studio_Trunk\workspace\src\sdksource\fileinput\dzassetdaz.cpp(6770): Parent for modifier not found: FBM3duG8FStylized2021_body.
    2023-12-04 12:36:23.397 [WARNING] :: D:\DAZDevel\Hudson\HUDSON_HOME\jobs\NB_Studio_Trunk\workspace\src\sdksource\fileinput\dzassetdaz.cpp(2485): Modifier not prepared: FBM3duG8FStylized2021_body!
    2023-12-04 12:36:23.399 [INFO] :: Creating modifiers...
    2023-12-04 12:36:23.590 [WARNING] :: D:\DAZDevel\Hudson\HUDSON_HOME\jobs\NB_Studio_Trunk\workspace\src\sdksource\fileinput\dzassetdaz.cpp(2502): Modifier not created: FBM3duG8FStylized2021_body!
    2023-12-04 12:36:23.693 [INFO] :: Creating property aliases...
    2023-12-04 12:36:23.702 [WARNING] :: D:\DAZDevel\Hudson\HUDSON_HOME\jobs\NB_Studio_Trunk\workspace\src\sdksource\fileinput\dzassetdaz.cpp(10128): Alias property reference not found: Genesis8Female:/data/DAZ%203D/Genesis%208/Female/Morphs/3D%20Universe/G8F/ctrlMouthOH.dsf#ctrlMouthOH?value
    2023-12-04 12:36:23.702 [WARNING] :: D:\DAZDevel\Hudson\HUDSON_HOME\jobs\NB_Studio_Trunk\workspace\src\sdksource\fileinput\dzassetdaz.cpp(2517): Property alias not created!
    2023-12-04 12:36:23.704 [WARNING] :: D:\DAZDevel\Hudson\HUDSON_HOME\jobs\NB_Studio_Trunk\workspace\src\sdksource\fileinput\dzassetdaz.cpp(673): Node for formula property not found:
        URI: Genesis8Female:/data/DAZ%203D/Genesis%208/Female/Morphs/Zeddicuss/Z%20Exercise%20Studio/Z%20EXS%20Squish%2004%20Morph.dsf#Z%20EXS%20Squish%2004%20Morph?value
    2023-12-04 12:36:23.704 [WARNING] :: D:\DAZDevel\Hudson\HUDSON_HOME\jobs\NB_Studio_Trunk\workspace\src\sdksource\fileinput\dzassetdaz.cpp(748): Formula target property not found:
        File: /data/Zeddicuss/Z Exercise Studio/Ball/Morphs/Zeddicuss/Base/Squish 4.dsf
        URI: Genesis8Female:/data/DAZ%203D/Genesis%208/Female/Morphs/Zeddicuss/Z%20Exercise%20Studio/Z%20EXS%20Squish%2003%20Morph.dsf#Z%20EXS%20Squish%2003%20Morph?value
        File: /data/Zeddicuss/Z Exercise Studio/Ball/Morphs/Zeddicuss/Base/Squish 3.dsf
    2023-12-04 12:36:23.705 [WARNING] :: D:\DAZDevel\Hudson\HUDSON_HOME\jobs\NB_Studio_Trunk\workspace\src\sdksource\fileinput\dzassetdaz.cpp(673): Node for formula property not found:
        URI: Genesis8Female:/data/DAZ%203D/Genesis%208/Female/Morphs/Zeddicuss/Z%20Exercise%20Studio/Z%20EXS%20Squish%2002%20Morph.dsf#Z%20EXS%20Squish%2002%20Morph?value
    2023-12-04 12:36:23.705 [WARNING] :: D:\DAZDevel\Hudson\HUDSON_HOME\jobs\NB_Studio_Trunk\workspace\src\sdksource\fileinput\dzassetdaz.cpp(748): Formula target property not found:
        File: /data/Zeddicuss/Z Exercise Studio/Ball/Morphs/Zeddicuss/Base/Squish 2.dsf
        URI: Genesis8Female:/data/DAZ%203D/Genesis%208/Female/Morphs/Zeddicuss/Z%20Exercise%20Studio/Z%20EXS%20Squish%2001%20Morph.dsf#Z%20EXS%20Squish%2001%20Morph?value
        File: /data/Zeddicuss/Z Exercise Studio/Ball/Morphs/Zeddicuss/Base/Squish 1.dsf
    2023-12-04 12:36:23.721 [WARNING] :: D:\DAZDevel\Hudson\HUDSON_HOME\jobs\NB_Studio_Trunk\workspace\src\sdksource\fileinput\dzassetdaz.cpp(697): Formula output property not found:
    2023-12-04 12:36:23.732 [WARNING] :: D:\DAZDevel\Hudson\HUDSON_HOME\jobs\NB_Studio_Trunk\workspace\src\sdksource\fileinput\dzassetdaz.cpp(697): Formula output property not found:
    2023-12-04 12:36:23.733 [WARNING] :: D:\DAZDevel\Hudson\HUDSON_HOME\jobs\NB_Studio_Trunk\workspace\src\sdksource\fileinput\dzassetdaz.cpp(748): Formula target property not found:
    2023-12-04 12:36:23.770 [WARNING] :: D:\DAZDevel\Hudson\HUDSON_HOME\jobs\NB_Studio_Trunk\workspace\src\sdksource\fileinput\dzassetdaz.cpp(748): Formula target property not found:
    2023-12-04 12:36:23.771 [WARNING] :: D:\DAZDevel\Hudson\HUDSON_HOME\jobs\NB_Studio_Trunk\workspace\src\sdksource\fileinput\dzassetdaz.cpp(748): Formula target property not found:
    2023-12-04 12:36:23.772 [WARNING] :: D:\DAZDevel\Hudson\HUDSON_HOME\jobs\NB_Studio_Trunk\workspace\src\sdksource\fileinput\dzassetdaz.cpp(748): Formula target property not found:
    2023-12-04 17:58:26.651 [INFO] :: Finished Rendering
    2023-12-04 17:58:26.758 [INFO] :: Total Rendering Time: 5 hours 20 minutes 10.57 seconds
    _______________________________________________________________________________________________________________
    352 MB in pg_xlog.  I think pg_xlog never exceeds 352 MB.  I could be wrong.
    2023-11 Cumulative Update Preview for Windows 11 Version 23H2 KB5032288 is available.  I'll update to that now.  DAZ Studio is functioning at the time of this post.  No more PNG transparency where there shouldn't be.  Lets see if that holds.
    Are you using Mac or PC?
    How are you installing your content?
    Are you logging in to Daz Studio?
    For DAZ I'm using PC.  Installing via DIM.  I am not logging in to DAZ Studio.
    After doing the aforementioned Win 11 update the Hudson GP errors came back in log.txt.  Those were the ones I was concerned about.  I'll have to uninstall DAZ Studio, reinstall it and open it online again otherwise the GP textures will be wrong again.
    You talk about using DS online and offline, that sounds like logging in and if you are using DIM to install your content, logging in to DS and letting Daz Connect inside DS 'update' metadata and products, is the only thing needed to make a mess of everything.
    Reinstalling DS over and over again does not fix problems in the Content Library
    What are the settings in DS Preferences -> Startup?
    522 x 244 - 14K
  • Because I am Blendering it (not logging in) should I dissable these?
    407 x 561 - 32K
    Yes
  • PerttiA said:
    Yes
    Thanks.  I'm trying it out now.  Nice to not have that annoying screen.  I did do a new Studio install just in case.
    I need to make a correction to a previous post.  I just installed all 3 Mesh Grabber products and while online I opened DAZ Studio via DIM and was able to use it without being asked to enter my admin password.  I previously stated I needed to enter my password.  This was not the case this time.
