My render stops at the beginning and won't proceed further
Hello everyone!
I need your help, please! I initially had an issue where it would show 'error during rendering' right at the beginning of the render. After fixing the SubD on the characters, when I start the render, it begins but stops after one minute without progressing further, and it doesn't display any error messages. What does this mean, and how can I resolve it? It was working fine until yesterday...
Thank you so much!
  • felisfelis Posts: 5,901
    Is it only image series you have trouble with?
    What are your pc specs (RAM, GPU)
    Try to attach your log Help > Troubleshooting > View Log File
  • Your scene has to many Verticies/Faces. try reducing your figures Subdivision to be no greater than 3 on the rendered subdivide - Select Figure>Parameters>Mesh Resolution> Render SubD Level (Minimum) to <=3
    I got this same thing and it was because I had mine set to 4 and it was to much for Daz to handle. Once I set it to 3 I was able to render with no issue
