Daz studio reporting errors frequently,When I switched to the 14th generation Intel cpu.
When I switched to the 14th generation Intel cpu, daz started reporting errors frequently.
Has anyone encountered this problem?
What are the errors?
crash,at the moment of moving the bones.
What about moving a cube promitive, or a figure a a whole? Is this a crash staight to desktop or do you get a crash report pop-up?
Uncertain, almost without any regularity, moving bones or objects can cause software crashes.
Sometimes I receive error reports, and the content varies each time, mostly due to errors in the DLL file.
Do you have a GPU on the CPU? Is that being used for the DS application display (assuming you also have an nVidia or AMD GPU on the system)?
yes,rtx4090,the CPU I used before was AMD 5900x, but now the problem has started to occur after replacing the motherboard and CPU.
I am currently trying to roll back the GPU driver to see if it can solve the problem.
But does the CPU also have an Intel GPU?
no.
However, the problem seems to have been resolved. After reducing the core ratio of the CPU from 56 to 54, daz became stable, but still needs to be tested.
