A3 and V3 materials compatibility?
srieschsriesch Posts: 4,243
Is A3 supposed to be able to share materials with V3, or not? I couldn't remember, so I tried, and found that a randomly-chosen V3 material seemed to apply to parts of A3, but not the middle of the legs.
    A3 and V3 are not related in any way, they are both standalone figures. A4, by contrast, is a morph of V4, so you may be OK there.
    There may have been texture convertors at some point for this
    Just looked in the store and there is this : http://www.daz3d.com/texture-convertor-2-tc2-bundle but I'm not sure if it converts from V3 to A3 or vice versa?
  • A_C_CA_C_C Posts: 21
    Actually A3 can use the same textures than V3, the prtoblem is that it had an aditional material zone in the legs (hence the blank space you note). There used to be an script in 2.3 that fixed that problem, but I don't know if it works with later versions of DS.
  • Richard HaseltineRichard Haseltine Posts: 109,292
    A3 is almost certainly going to be using the Default DAZ Shader so you can just select one of the leg surfaces that is textures, Edit>Copy>Copy Slected Surface, select the knee area, Edit>Paste>Paste Selected Surfaces.
  • HavosHavos Posts: 5,623
    Anyone know why A3 (and only A3) got this material quirk. Is anime/manga themed art big on different colored knees?
  • SupercopeSupercope Posts: 128
    edited June 2015
    H3 can use MATs from M3 and D3, but has the same issue.
    The script is A3 H3 LegMat Fix (LegMatFix.dsb) by DeltaX15.
    However, I believe that .dsb files don't work past certain versions of D|S. It is working in 3.1, but not in 4.8.
    Post edited by Supercope on
    DSB is a binary (compiled) script and it's probably the deprecated functions around the DS 4/4.5 time. It can't update because it's compiled.
  • KeryaKerya Posts: 10,943
    For creating second skin clothes - something that is rarely used nowadays.
  • MattymanxMattymanx Posts: 7,000
    ALL Generation 3 Characters can use the same maps. Aiko3 and Hiro3 have a few extra mat zones that will require manual setup but can easily be done in the surface tab with copy and paste. Then you can save out your own preset for them.
  • srieschsriesch Posts: 4,243
    Copy & paste works fine to fill in the gaps, thanks everybody!
  • robkelkrobkelk Posts: 3,259
    There's an add-on script that might work in later versions of D|S:
    http://morganrlewis.deviantart.com/art/Gen3-Leg-Material-Fixer-Scripts-for-Daz-Studio-403711774
    Hiro 3 got the same quirk. I don't know why, though.
  • Eustace ScrubbEustace Scrubb Posts: 2,730
    edited July 2015
    H3 is mesh-identical to (in other words, might as well be an MT of) A3.
    Another useful tool (I toot my own horn) is http://www.sharecg.com/v/33086/view/11/Poser/The-Mad-Albino-with-UniMAT-Merchant-Resource -- it comes with an albino male skin, but the MR part is that you can put any Gen3 skin into the PZ2 and apply it to any comparably-mapped figure.
    And a DSB is not necessarily encrypted or binary; it's just compressed from the DS/DSA version. The encrypted version is DSE.
    Post edited by Eustace Scrubb on
