How many DAZ scenes do you have saved.
As of this moment, I am up to 11,187
  • FSMCDesignsFSMCDesigns Posts: 12,849
    116 GB in 4 folders, usually corresponding with the version of DS that was used. That may end up being much less soon since I just ordered a new PC and if history is any indication, the file paths and install will probably break these saved scene like they have done in the past.
  • Maybe 200? I render and delete most.
  • StezzaStezza Posts: 8,872
    none smiley
  • Stezza said:
    none smiley
    You don'tsave the work that you do?
  • I save customized figure bases that I think I'm going to use more than once in my stories, and once in a while I save a set that I know I'm going to reuse, especially if it was a very long setup job and/or a huge kitbash, but mostly the policy is "don't keep anything I don't think I'm going to need again," just for space reasons if nothing else.
    If a particular recurring character is, say, a straight load of Latonya 8 with no alterations, I don't save a base, I just keep a line in my notes that says "this character is straight Latonya" and maybe some notes about hair used, etc. But if they've got a lot of tinkering, I save the base so I won't have to remember what I did. A lot of my characters are custom mixes of several figures.
    I have a much smaller number of custom sets. Mostly I keep notes like "such-and-such lives in the Architect's Penthouse set," and don't need more than that.
    What I don't like deleting is the RENDERS. I keep pretty much all of those.
    I never use a figure as is from the store. They are all just part of the gene pool for when I create a character for a particular scene i am working on. I save every WIP, sometimes at various stages of development. I also like to go back and revisit a scene when I am not feeling very creative and also apply new techniques, products or ideas I have learned since i saved it.
  • Yeah. The ones I use straight out of the box tend to be only for "walk-on" parts. I don't take the time to customize when I'm filling the scene with extras.
    I am experimenting on ways to use various elements that come with characters, but I don't use the characters themselves. I save almost everything, theoretically to see my path as I try new ideas.
  • DartanbeckDartanbeck Posts: 21,988
    Drogo Nazhur said:
    Stezza said:
    none smiley
    He's a Genius Carrara Artist! Doesn't use Studio, I don't think. Not for rendering and save at least.
    Myself, 193GB since 07/27 2023 - this year. In all fairness, I'm doing animations with simulated Mesh hair. Takes up some room. But I can't quit! I just keep making more!
    Prior to that date, I was dangerously low on space so I bought an 8GB HDD to hold me over until I can get more. In my own stupidity, I suffered a complete data wipe of everything before then. Probably about 1.5TB+ of saved DS scenes... lost in the ether for good! :(
    I just took as a good sign to move forward. I've been happy starting over from scratch.
  • about 1K at most, I mostly save characters and scene subsets as rarely redo a scene
  • semperequstrisemperequstri Posts: 150
    edited November 2023
    About 25 or so, but those are Scenes/ subsets I use repeatedly for setting up larger reference scenes for my 2D artwork . Once the 2D piece is done I delete the reference scence I made in DAZ.
    Post edited by semperequstri on
  • BejaymacBejaymac Posts: 1,965
    Four
    1 for rendering thumbnails
    1 for creating cards for morphs
    1 for testing 3DL shaders
    1 for testing Iray shaders
  • Certainly in the tens of thousands, but I'm not counting. I generally never delete, just redundant save to portable storage. so since 2008...   they're adding up.
  • crosswindcrosswind Posts: 9,704
    Myself,  75GB, since 2017, appr. 15K duf files, incl. scenes and products.
  • LinwellyLinwelly Posts: 6,069
    6.4 GB though there are more of the older ones on the external HDD
    I do wipe out older ones every now and then but keep all the scene sets I made for the comic
    there is another worth of 2.6 GB Scene Subsets
  • no noseno nose Posts: 315
    a bit more then a thousand, I thought it was a lot, but it's apparantly lower then the average
