I reinstalled Windows and now all the base poses preset are gone, how to manually get them back?
You presuambly lost your database, and will also have lost your content diectory settings if they were not default. As long as you didn't format the drive you should be able to recover the database, though if you use Install manager (or Daz Central, formerly) to install you can also reimport metadata if you don't care about your own, or used the Export userdata command. First, an you see your files in the Content Library under Daz Studio Formats?
