Scenes suddenly taking forever to load
Hi all, all of a sudden, since a couple of days ago, almost any scene is taking forever, like 10-15 minutes to load. I am at a loss as to why. Wondering if I should reinstall the program. Any thoughts appreciated.
    How big are your savefiles?
  • ChoppskiChoppski Posts: 631
    PerttiA said:
    How big are your savefiles?I
    I am not sure. THe scene says its a few MB. Most are just figures I have morphed and saved. But in a couple cases it was a full scene, maybe 45 MB. Unless I am not looking in the right place for the size.
  • TheKDTheKD Posts: 2,711
    edited November 2023
    Go to help > troubleshooting > veiw log file. Control A, backspace, control S to save it, then close it. Then try to load a trouble file again. After that, view log file, and see if you see any loading errors.
    Post edited by TheKD on
    ok, I will try that. Curiously, I ran a windows memory check, which showed everything was fine, and now I am not having issues.
  • Make sure your video driver is up to date. I had a similar problem last week and it turned out I needed to update mine.
    I will check that also. Thank you
