Daz studio 4.22 IRAY problem
csuky13031977csuky13031977 Posts: 33
Helo ... I recently updated my Daz with version 4.22... since then I can't open many things in IRAY view because DAZ automaticaly shut down and ..and the error shown in the attached photo appears... does anyone know a solution to this? or send a 4.21 version, I didn't have such a problem with it...thanks in advance for the answers
Post edited by csuky13031977 on
  • What graphics card do you have?  Try updating its drivers.
  • Out Of Touch hairs or shaders? This is a known issue, though if you use Daz Central/Install Manager or manual installs several of them have been updated to fix the problem, try checking recent ones for updates (it's a shared file so one updated install after any old ones should resolve the issue). If you can't resolve the issue that way select the hair, go to the Surafces pane and in the Editor tab select the hair again, then make sure that the transmitted colour doesn't have a map applied. This issue is in the release theads so I am closing thie one.
