Adding dForce to my jacket not working
I updated yesterday to this version. I am now unable to add dForce to a newly created/rigged jacket I'm working on. I used to add dForce to my new creations all the time. But now I'm unable to. Please try adding dForce yourself and tell me it's not just me.
  • I had to go under my scene tab edit > Geometry > Remove dForce Modifier... then re-add dForce through this tab to finally see all of the expected dForce settings. (NOT under my Simulation Settings pane)
  • DartanbeckDartanbeck Posts: 21,988
    So you got it working?
    That's odd though. I was just using the dForce options in the Simulation pane and they all seem to be working - except that I haven't tried to add new dForce properties to something that didn't have them.
    Did you, perhaps add a new surface selection? When I do that, the dForce properties won't carry over from the other surfaces - even though the selection of polygons had dForce prior to being reassigned. I just select that new surface and apply new dforce - works.
  • felisfelis Posts: 5,990
    I have never had any issues adding dForce to an object.
    What if you create a plane, and add dForce to that?
    Else describe your workflow.
