Barfly Poses G8F 01
You started out just planning to have a couple of drinks with a friend, and before the end of the night your tab is maxed out, you've forgotten how to walk in these stupid heels and you've lost your underwear.
A collection of 5 poses in a social drinking theme, for Genesis 8 Female (designed around the default shape). To use, select a figure and load any of the pose files; adjust for contact with floor/other objects and/or body shape as required. Can never have too many poses right?
NB: These poses are built around a standard bar height (42 inches/107cm), standard G8F character height, and the heel height of my CFM Pumps (also free), with a lot of close contact with the bar prop. If you are dealing with a customized character or different shoes, the simplest thing to tweak is the bar height rather than the pose, you can just scale the bar down on Y axis.
NB: If you don't have a suitable prop to use for the bar, you can just create a cube and size it to 42 inches tall!
Download: ShareCG
Download: Google Drive
Got them and thank you.
Nice, thank you
