dh horse3 addons
hi
i loaded horse3 all ok
added basic textures all ok
added the dh wings to horse3, but there seems to be a problem where the wings attach to the body
any ideas how to fix this?
  • LeanaLeana Posts: 12,889
    I think you simply need to apply the horse texture to the white part of the wings geograft.
    There should be a hierarchical material preset included to apply the texture to the horse + add-ons at the same time.
  • Which tool is active (checked in the Tools menu)?
  • KeironKeiron Posts: 419
    Hi
    surface selection is selected
    if i change the base colour of the wing it improves but not good
    edited November 2023
    i can change the base colour of the horse
    i can change the colour of the wings etc
    if i select dh all, then it changes the dh parts but not the horse body colour to match it
    i can change all the different parts to the colours available but they all give the same result as in the render i uploaded
    here ive changed the horse colour and the hh wing colours but i get the same issue set tool to universal
    tried adding the horse texture to the wing base, but no good
    1920 x 1186 - 997K
    Post edited by Keiron on
    Hi Richard found the solution
    Not sure why daz crashes by using the daz Horse 3 with the main etc then adding pegasus or dh wings
    It looks like you can copy the coat texture from the horse to the pegasus wing coat to overcome the issue I'll try ther dh wings next
    Using apply all doesn't add the texture to the horse
    Update
    You can do the same to the DH wings
    1894 x 1041 - 889K
    3840 x 2160 - 3M
    Working fine with method it's a shame it just doesnt do it
    3840 x 2160 - 3M
