Import "Solitaire"-Bedroom-Set in Poser
Hi,
I want to use the "Solitaire"-Bedroom-Set (http://www.daz3d.com/solitaire-by-meipe), but I don't know how I can import it into Poser? I've installed it by the DAZ Install Manager, but I can't find it in the library.
Does anybody know how it works?
Thx
This set comes with both a DS installer and a Poser installer. did you use the correct one.
This set has both Poser and DAZ Studio files, so it will work in Poser without any problems. There are even Poser Lights (LT2) and PZ2 files for materials and CR2 and PP2 files as well.
If you installed this using DIM, go to the Installed tab, right click on the item, and select 'Show Installed Files' that will tell you what was installed and where it was installed to. Poser content is usually installed to the 'Runtime' folder inside My DAZ 3D library. Did you make sure that you have the Poser filter ticked in the DIM 'Ready to Download tab?
Thank you! I installed the wrong one... :red:
