Genesis 9 and bone minion
Anyone else having issues with the arms of genesis 9 when you use bone minion for gen 8? I find the arms often twisted badly, and doing a zero pose for the arms does nothing. Racking my brain trying to figure out how to fix this.
  • felisfelis Posts: 6,137
    Have you adjusted rigging to shape?
  • DaventakiDaventaki Posts: 1,624
    Mine is working fine.
    Couple things just to cover bases:
    1. Load G9 and make sure it is selected in the scene tab
    2 Best to run the turn limits off script that Riversoft supplied
    3. Run the Bone Minion Genesis 8 Female (or male if thats the poses your using)
    4. Select the bone minion in the scene tab
    5. apply pose.
  • crosswindcrosswind Posts: 9,743
    Turn limits off..
  • ChoppskiChoppski Posts: 641
    I always do the turn limits off. I can try the adjust rigging to shape. It's happened several times.
    If name the pose from which product, we may check and try...
