View area layout lock
plarffplarff Posts: 282
edited November 2023 in Product Suggestions
Hi All
Is there a way to LOCK the main view area so one cannot resize it by accident. I have it setup the way i like it. I do load a save Render settings file at startup and I do not need to fiddle or save my Viewport, just the main area as per attached image.
I read somewhere one can save the layout and then call up each startup but this still doesnt solve my issue where i sometimes accidentally resize the windows. If it's not possible then i believe it would be a nice feature.
Another feature is to make New Window default selected when doing Spot renders and NOT Viewport.
Thx
Post edited by plarff on
  • felisfelis Posts: 5,959
    You could create a camera view 'apply viewport transforms' and lock that.
    You cannot lock the viewport.
  • plarffplarff Posts: 282
    Hi Felis...
    Okay, who do apply viewport tranforms? PIty that one cannot lock the layout. We musn't confuse Viewport with DAZ "view" layout here as I believe they are two different things.
    Ok i think I may found an answer by watching a tut. And I should've called it the interface not viewport or layout.
    https://www.youtube.com/watch?v=T63FvHumppY
  • The Viewport is what is left after other pane groups are sized - If you set the Dimension Preset to Active Viewport then that will change - there is, as far a I am aware, no way to lock the pane docking area widths.
  • c567591ac567591a Posts: 45
    There certainly is a way to lock this... have an option in settings to DISABLE sizing windows by grabbing the edges.  Then if this is set, ignore the size request drag/selection.  Another thing to help would be to put the size ###x / ###y visible somewhere whilst this is being changed so if this does happen, we can get it back to whe numbers at least where we had it.
    I fairly often screw up my layout accidentally as my hands are shaky and stuff happens.  This is frustrating to get things working good and then all of a sudden drag it and never can get it quite back.  Its a user experience as well as a disability improvement if it can be added.
