Help With Glowing Things in Viewport?
I looked for an answer to this problem but I couldn't find one. Is there something I can do about my objects' appearance in the viewport? They seem to glow this horrible bright white that is very difficult on the eyes and I can't really see what I'm doing. Any info or tips would be greatly appreciated.
  • felisfelis Posts: 6,040
    edited November 2023
    Your viewport are in Filament.
    Either chage to texture shaded, or create a Filament Draw Options node and adjust Environment Intensity Scale. Would suggest 5000 and see how that looks.
    Post edited by felis on
  • crosswindcrosswind Posts: 9,680
    You have Filament DrawStyle in Viewport. If you don't like its VE, just press Ctrl + 9 to switch back to Texture Shaded DrawStyle.
    1486 x 1302 - 211K
    Post edited by crosswind on
    Thank you! That helped very much
    While crosswind's direction helped, I would really love to know what you said here and how to apply suggested options you have mentioned. (Lol) I have no idea what I'm doing.
    I'm not a Filament lover but here's what felis mentioned - as below. either change ISO Scale or Environment Intensity Scale if you'd like.
    2560 x 1400 - 944K
    Thank you!
  • oddboboddbob Posts: 444
    I like filament but the default options are a blown out mess. My default scene has a filament draw options node and camera settings that I like. I use the attached settings for general use stuff and get a reasonable match between viewport and iray renders.
    921 x 731 - 84K
