Making composite objects
Is there a way to glue several parts together to make a composite part? Which I can then view from various angles.
  • felisfelis Posts: 6,152
    Really merging them, no
    You can put them in place, and then you can parent one to another. Then if you move the prime object the other will follow.
    Although I would recommend to take it into a modeller and actually merge. It looks symmetrical, and if you can just use a mirror modifier (in blender at least).
  • crosswindcrosswind Posts: 9,747
    Are they in DS? If they are, you may export them to a single obj file, and import back...
