New Ghost light feature shows not up
I watched the new ghost light feature and would tried out by myself, but the dialogue box did not show up.
Do anyone have the same problem?
Even a restart did not make it happen
Version is pinned to the attachment.
  • Have you updated the Default Resources product, as well as Daz Studio itself?
  • LadyNightVampLadyNightVamp Posts: 70
    edited November 2023
    I've found the script under scripts, utilities. It's version 4.7 of 2023Oct19. I hope it's the right, because under products, D, I couldn't find it.
    Post edited by LadyNightVamp on
  • felisfelis Posts: 6,519
    In latest beta, the scripts is version 4.7, and there it is both under scripts and in Content Library > Products > Default  Resources
  • daybirddaybird Posts: 678
    I think I expressed myself incorrectly.
    According to the video, a pop-up menu should appear when I click on the script, but nothing happens for me.
    As you can see on the screenshot, I found the script, but nothing happens when I click on it.
  • crosswindcrosswind Posts: 10,276
    From your screenshot, it seems that you got the script by searching in Content Library, right? If so, that script is more likely the old version. How many Daz Library do you have?
    A simple way - If you installed Default Resources package via DIM, open DIM - Installed tab, locate the package. Follow the screenshots down below.
    If it works, creat a custom action for it.
    1151 x 954 - 72K
    1151 x 954 - 130K
    808 x 1439 - 101K
    Post edited by crosswind on
    Wow, thx a lot. I'm now able to make it work, but only if I hit the script in the tab and not in Daz himself.
    Must I drag it manually in the daz folder?
    Yup, pls drag to overwrite the script file there and try again.
