Adding to Cart…
Does the popup say completed successfully without any message like "geometry did not match" or "no deltas"?
If there's no error message I'm not sure what the issue would be. Usually it refuses to create the dial if there's a problem.
EDIT: OH wait.
Your pic says "jumperdress." Isn't that the name of your dress and not G2F?
Yes - it completed successfully.
Jumper Dress is what I'm morphing, not G2F.
Here's the export settings ...
I'm afraid I'm a bit stumped, then. Like I said, usually it won't create a dial at all if it's not going to work. Those settings are fine.
No worries.
It's getting a bit late here anyway. I'll have another go tomorrow.
Thanks again.
Ah I see, you need to check on "apply modifier" for blender export setting.
I know, you do not apply any modifier though you need it check "on" for shape key modified obj.
Without it you may export base shape I think.
I usually not tweak my export setting, and when I export, "pin" ON for shape key.
(it is useful to export each shape key obj, without check each value^^;)
and keep check on "apply modifier"
today I set as same as your pic,
then export morphed shape, I need to keep option "apply modifier" .
I feel strange, why ds make controller for you , when I try same thing, it just return
"No deltas for morph, skipping node, Created moprh successfully (but do not make controller)"
sickleyard pointed,,
maybe there is another pattern for each morph loader setting
but you may try , check it on.
What it's looking like, since the morph is doing nothing dialed to 100, is that you exported the base instead of the shape key. I have found that not only do you need to have the shape key dialed to 100%, but the one you want needs to be selected.
You are correct :) Apply Modifier did the trick.
Thank you again.
