DS 4.22 IRAY's not working (SOLVED)
MasterstrokeMasterstroke Posts: 2,337
edited November 2023 in Daz Studio Discussion
DS 4.21_05 worked like a charme. Iray rendering hasn't been a problem. The new IRAY in 4.22 build doesn't work. Render screen remains empty.
Post edited by Masterstroke on
  • Oooopsy Driver problem.
    for anyone having a similar problem, make sure to have the latest Nvidea GPU driver installed.
  • My Nvidia driver is 2 days old. The iRay render doesn't work :-(
    How can I get the previous version?
    This is the 3rd time the Daz update sucks. Thank you, never more
    What is your GPU? What happens when you try to render? have you checked the log (Help>Troubleshooting>View Log File)?
  • EdsArtEdsArt Posts: 14
    edited October 2024
    This worked for me too.
  • frisquetfrisquet Posts: 0
    I guess no one have that problem anymore but I haven't found any solution. Always renders just blank image and iray preview is infinitely running with smooth shading. All drivers for my geforce rtx 4060 are up to date and I got no issues to render in blender or marmoset.
    2026-02-09 20:31:26.628 Iray [INFO] - TRAV:DATABASE ::   1.0   TRAV   db   progr: Traversing scene.
    2026-02-09 20:31:27.222 Iray [INFO] - TRAV:DATABASE ::   1.0   TRAV   db   info : Traversing scene took 594.225 ms.
    2026-02-09 20:31:27.224 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating geometry contexts.
    2026-02-09 20:31:27.225 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating geometry.
    2026-02-09 20:31:27.225 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Importing scene graph.
    2026-02-09 20:31:27.377 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Auto instancing compression 1.0x (Full instancing compression 1.0x)
    2026-02-09 20:31:27.377 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Importing geometry for motion time 0
    2026-02-09 20:31:27.545 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Geometry import (1 triangle object with 8 M triangles, 1 instance yielding 8 M triangles) took 168.972 ms
    2026-02-09 20:31:27.545 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating motion transforms.
    2026-02-09 20:31:27.545 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating section objects.
    2026-02-09 20:31:27.545 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating materials.
    2026-02-09 20:31:27.597 Iray [INFO] - MATCNV:RENDER ::   1.0   MATCNV rend info : found 375 textures, 0 lambdas (0 unique)
    2026-02-09 20:31:27.597 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating environment.
    2026-02-09 20:31:27.598 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating compiled material code.
    2026-02-09 20:31:27.598 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating compiled environment code.
    2026-02-09 20:31:27.598 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating material textures.
    2026-02-09 20:31:27.602 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating environment textures.
    2026-02-09 20:31:27.602 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating BSDFs.
    2026-02-09 20:31:27.602 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating volumes.
    2026-02-09 20:31:27.602 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating lens.
    2026-02-09 20:31:27.602 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating lights.
    2026-02-09 20:31:27.602 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating object flags.
    2026-02-09 20:31:27.602 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating backplate.
    2026-02-09 20:31:27.602 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating compiled backplate code.
    2026-02-09 20:31:27.602 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating backplate textures.
    2026-02-09 20:31:27.602 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating decals.
    2026-02-09 20:31:27.604 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Using iray core convergence estimate.
    2026-02-09 20:31:27.604 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Allocating 1-layer frame buffer
    2026-02-09 20:31:27.604 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Using interactive scheduling, caustic sampler disabled
    2026-02-09 20:31:27.604 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Initializing local rendering.
    2026-02-09 20:31:27.606 [WARNING] :: \src\pluginsource\DzIrayRender\dzneuraymgr.cpp(373): Iray [ERROR] - IRAY:RENDER ::   1.0   IRAY   rend error: No device specified or usable
    2026-02-09 20:31:27.606 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Rendering with 0 device(s):
    2026-02-09 20:31:27.606 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Rendering...
    2026-02-09 20:31:27.606 [WARNING] :: \src\pluginsource\DzIrayRender\dzneuraymgr.cpp(373): Iray [ERROR] - IRAY:RENDER ::   1.0   IRAY   rend error: No worker to render with: aborting render
    2026-02-09 20:31:27.606 [ERROR] Iray :: Internal rendering error.
  • Richard HaseltineRichard Haseltine Posts: 108,949
    In 4.22 or in the current version?
    4.24.0.4 (64bit)
    4.24.0.4 (64bit)
    OK, then what is your driver version - and is it Studio or Game Ready?
    4.24.0.4 (64bit)
    NVIDIA Studio driver
    Version:  591.74 - Released : Mon, Jan 5, 2026
  • It might be worth trying an older driver, if you don't have somethign else requiiring the newer. I am having no issues with 576.88
