Where are my saves?
vindazivindazi Posts: 671
edited June 2015 in Daz Studio Discussion
When I save various scenes into the DAZ library they are not showing up. How do I get DAZ to recognize them?
Post edited by vindazi on
  • fixmypcmikefixmypcmike Posts: 19,709
    Your saved scenes folder is in [yourname] > Documents > DAZ 3D > Studio > My Library, but your Content Library screen shot is showing "My DAZ 3D Library" (which is probably in Shared). Do you have both paths listed in Content Directory Manager? The default is to have both, the Shared folder for installing content and the My Library folder for saves, but if you had an older version installed at some point it would have retained your content folder settings.
  • vindazivindazi Posts: 671
    It is quite likely that somewhere in the process of upgrading something got misplaced. How can I fix it?
    You need to add the path to Edit > Preferences > Content Library > Content Directory Manager under both DAZ Studio and Poser Formats
    It is easy enough to do, select DAZ Studio Formats, click on Directory > Add and browse to where your folder called 'My Library' is, then do the same for Poser Formats.
    edited June 2015
    The "grounds" are typically only under the content. How can I make grounds meet the sky? For example, how can I replace the gray with the ground under the house a gate in this image?
    934 x 547 - 494K
    edited June 2015
    I don't see an option in Daz for "DAZ Studio Formats". Where would I find that?
    Never mind, I misunderstood what you were saying.
    Thanks, that worked.
