Jumbo!
Hello everybody,
I'm having some fun with this one https://www.daz3d.com/jumbo-jet-vip-expanded-for-iray but I can't find a way to let passengers get in through the doors. Does the plane have hidden stairs I cannot find? Or could someone suggest some compatible airport prop? I found some airport ground vehicles on Rend.. but they are for Poser.
Thank you in advance!
I'm not sure if these stairs are tall enough.
https://www.daz3d.com/aircraft-deck-props-set
Moved to Technical Help as it is a question about an existing product, not a Product Suggestion.
Whenever I've boarded a jet that big, it's been along a gangway (apparently the correct term is jet bridge) rather than climbing up and down any stairs. You could probably bash together the interior of one of those using primitives and shaders. None of the airport models I could find have them though.
For stairs, how about this? https://www.renderosity.com/marketplace/products/99375/airport-ground-support-vehicles
-----------> For stairs, how about this? https://www.renderosity.com/marketplace/products/99375/airport-ground-support-vehicles <---------
That would be perfect, but can I use Poser props in Daz? (newb here)
Yes, though if they use "advanced" (oser 5+) materials the settings won't import and you will need to rebuild the surfaces. Also externasl morphs (.pmd files) don't work in a lot of forms.
There's also this if you prefer a jet bridge. https://www.renderosity.com/marketplace/products/149829/airport-terminal-for-daz
Thank you everyone for your suggestions, in a little while my passengers will be happier :)
