I am uable to open the Scripts drop-down menu
I'm trying to make the Daz-Blender bridge work, but I am unable to open the Scripts dropdown menu.
The other menus, like File, Edit, Create, Window, Help etc.  work fine. Only the Scripts menu does not respond when I click on it.
Anyone know how to fix this?
  • crosswindcrosswind Posts: 9,645
    You use the latest version of DazToBlender bridge? If so, its in File - Send to.. menu item. Not sure if the latest bridge works with 4.15...
    571 x 624 - 50K
  • Hmm... That does seem to work. Thanks!
    It doesn't solve the issue of the Scripts drop-down menu not working, but at least this works.
    As for 'Scripts' menu item not working, you presse F3 to check the setting there. Create a Custom Action for a script and see it could be added to the Scripts menu or not.
