V4.2 Morphs++ Not Working in DS 4.8 (Update: Problem Solved)
Has anyone else had trouble getting V4.2 to take the shape of your character morphs since upgrading to DS 4.8?
So far, I've tried applying Darcy and a new character named Leah, and neither one of their morphs will load. Their shaders work, but their morphs don't.
I re-installed V4.2, her morphs++, and ran her associated DzCreateExPFiles-V4.bat file. When I tried re-loading Darcy and Leah's morphs again, nothing happened.
Post edited by Nyghtfall3D on
I have Darcy for V4, and I just tried it.
It works fine for me in 4.8, using the INJ morph PZ2 files from Pose > Darcy, both the Body and the Face morphs.
There are 31 files in that folder, and they all do what they should as far as I can see. I loaded V4 with the Powerloader, Base Morphs and Morphs++.
Have you looked at the log file to see if there are any clues as to what is happening? Are you saying it worked in 4.7 but not in 4.8?
I've solved part of my problem. DS looks like it's reading V4.2's morph injections when I click the INJ icon, but when I examine the Parameters tab, none of her morphs++ actually appear.
Looking at the download page, I see multiple files for both V4.2 Base and Morphs++
Victoria 4.2 Base
Victoria 4.2 Base StudioCF
Victoria 4.2 Base PowerLoader
Victoria 4.2 Morphs++
Victoria 4.2 Morphs++ StudioCF
Victoria 4.2 Morphs++ PowerLoader
Victoria 4.2 Morphs++ Developer Kit
I only downloaded Base and Morphs++, thinking they were all I needed. Do I need the others, too?
Problem solved. I downloaded and installed the rest of the files - all but the Developer Kit.
That PowerLoader is pretty snazzy. :)
Glad it's working now.
I always use PwoerLoader, you can see exactly what you are loading, and it does it all in one go, a great idea.
