Iray Preview Loops, Iray Render Hangs, DS unresponsive.
BlueFingers
I have a scene that causes my Iray Preview to loop in a "Preparing Scene" phase, if I try to render it, it gets stuck on "Iray (Scene Update): Updating Section Objects" (see screenshots). When I try to get back to Texture Shaded from Iray Preview, DS freezes and becomes unresponsive, same goes for trying to exit rendering. How can I remedy this?
Post edited by BlueFingers on
If you have an Nvidia video card and updated the driver recently, that could be the reason. The same thing happened to me after I updated the driver and finally, I had to reinstall the previous version for it to work correctly again.
Thanks, my drivers were from the beginning of september, I just updated them to see if that would help but it didn't. What are the best drivers for Daz Studio at the moment?
Edit: I also just noticed DS uses quite a lot of RAM with that particular scene, other scenes render and give a preview just fine. When shutting DS down after loading that scene, DS remains active in the background and won't shutdown and I am forced to "end process" DS in the Windows Taskmanager.
I found the culprit. I was the rug of Perfect Pinups: Film Noir Sitting Room. I think it's one of the material alternatives that was causing it.
Great! Glad that you found it.
