Generation 4 Problem
Faeryl Womyn
Hope this is the right thread. I downloaded and installed the newest Daz back in Feb. I also installed the genesis and generation 4 models. Problem is Victoria. None of the morphs++ work except two male morphs and when Aiko loads the eyes will not set in properly. For some reason since I did not use the install manager, I dont get that little icon thing to initialize like I use to, it's not in the zip and this may be why all this is happening. Hiro also reacts the same way on M4 with the whole eyes thing and the heads load large.
In my products sections of my account. I only get two options, the zip files or the installer manager option. I don't use the manager and I don't have internet at home to be able to use it.
Any help with this would be appreciated to get the morphs working right.
You don't need to have internet access to use DIM - just place the zips in the downloads folder and it will run the installs for you. In any event, since you didn't use DIM you need to go to \Runtime\Libraries\!DAZ and run the DzCreateExPFiles-v4 batch/command file to create the needed "index" files for the figure's morphs.
Thank you and will try that. As you can see from how long it took me to get online and read this, not having internet is a real pain...lol
