Snug Living Room props won't render
Hi,
Can someone confirm if they're having this issue too please? The Snug Living Room set comes with 2 table props (coffee table and lamp table). For whatever reason, I can use iray preview with them but when I go to render them Daz won't render and says there's an issue with renderer and if I try to render anything afterwards I get an error saying "the renderer is already in use". Quitting and relaunching Daz is the only solution to "unlock the renderer".
I get this same generic error message when I look at the log file from when started up the render.
[WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(369): Iray [WARNING] - API:DATABASE :: 1.0 API db warn : Transaction is released without being committed or aborted. Automatically aborting.
The other props in the set render just fine, just the two tables. Can someone spot me on this if they have the same issue before I open a ticket?
Thanks.
Iray preview and renders work okay for me, full scene or stadalone.
Thanks, I'll try uninstalling and reinstalling it.
